I´m trying to generate a grid that is slowly rotating and disappearing as soon as I get closer to a tree. It should be a super simple task but somehow I´m missing something
There are a few things going on, this smells a lot of AI generated code (which I also use btw :D)
you have 5 Curves to represent 5 different trees in your input: unless you want to generate 5 overlapped tiling solutions, each of which accounts for just one tree at a time, you need to set the Trees input to List access:
the second problem is that the first Output of the Python component is dedicated to getting errors and Print results, not a real variable output, it’s indeed named “out” to distinguish from “a”, “b”, “c” outputs:
you just renamend the out into Tiles, but that is still the “out” output and won’t receive program variables: you need to rename Tiles into “out”, then add an output that will be called “a” and rename that into “Tiles”, like this:
