Deformation column high rise building
I am struggling with a script to show the deformation of a single column using Kangaroo. The column consists of parts with the grain of the wood aligned to the column direction and parts with the grain perpendicular to the column direction. Both part have a different E modulus.
The total reaction force simulated by Kangaroo looks okay, but with the deformation of the column parts something goes wrong. When changing the heights of the parts with the grain perpendicular to the column direction, the overall change in deformation stops and stays around 93mm. Probably there is something wrong with my Kangaroo goals input.
construction column Kangaroo.gh (53.3 KB)
@DanielPiker could it be I misinterpret the working of the length line goal in the script?
Wth the K2Eng components I managed to get the correct results.
