Hi Everyone.
I’m facing a problem that I’ll try to describe since I can’t share any images of the bug.
I’m working on a project that has become quite complex, and I thought i salved most of the bugs on my side, but Shapediver behaves differently with the same parameters set up, compared to definition when i run it locally on my pc.
The procedure is: I upload a 3dscan, shapdiver generates a surface out of that, and then i can apply some mesh elements on the surface using the “splop” component.
The bug consists that sometimes and not always, on shapediver the mesh results rotated by 90°.
Hope this was clear enough.
Does anybody know what’s the reason behind this behaviour?
It it difficult to say what the issue could be without more information. I am guessing splop or another component of your definition produces variable results depending on Rhino versions or even local configurations (typical unsafe operations in Grasshopper). If you can reproduce the example using a definition with a minimal number of components, I can have a look.
Thank you Mathieu. Yes i understand but i can’t publish anything…I tried to give some extra conditions though on the orioentation plane while using Splop in order to double check before doing the actual operationm. Need to test a little more to see if that works.
