Define start points for diamond panels division on surface
Hi all,
I’m trying to recreate the reflector net in the Fulton Center. My method was to create the overall shape using a surface and then use the lunchbox diamond panels to create the outlines of the tension cables and the panels themselves.
The only issue being that I need to be able to define where the diamond panels start, so that they align with the radial grid and the cable ties at the bottom of the net.
Is there a way that you can divide a srf into a diamond grid/panels, but be able to define where the points for that grid starts? Thanks in advance.
fulton_GH.gh (26.0 KB)
Here are a couple of possible options, both with and without the Lunchbox plugin.
fulton_GH_v2.gh (31.6 KB)
Thank you very much Adam. I learnt a lot from that.
