hi. im trying to define the same distance between the vertical frames…
i am at the beginning of grasshopper and I tried to define it with the number of frames along a line but it does not work…
had anyone time to explain it to me?
it would be so helpful!
yes it works so far… but the last output of the lofts create vertical elements which are not in same distance…
I try to create a regular handrail but I tried for hours to get the vertical regulary…
this green ones…
it should be a kind of handrail and the baseline is defined about sections in different heights… until the perp frames I had the feeling it works but then at the end I lose some how this regularity…
so for that last turn I think what you create is the right one… but how could I combine the beginning and the end? … cause I had the different heights about the section at the beginning and I could count the verticals and I could twist them… but somehow I lose the regularity…
I thought of the same, but I also had the idea that in the definiton some things a redundant, so I tried to improve. But most likely the real problem is, that no one understands what she is trying to archieve.
I think there are many much better ways to get to the very same final outcome regarding the handrailing system you are working on, but probably this was one that had the less impact in your own workflow
