I am using the Define Linked Block component and by default it seems it sets the Layer Style to “Reference”. For my use case I need the Layer Style to be “Active” though. Is there a way to set this in the Component and not have to go through all the blocks manually to change the Layer Style?
Alternatively is there a way to change the Layer Style of a linked block from GH?
Thanks for any hints.
Unfortunately there is not a way to do this right now in the Elefront component itself. That’s a feature we’re looking to add in the next version, along with allowing for Embedded-and-Linked as an option.
I know your pain on having to go through block by block to change it.
In RhinoCommon you can access the LayerStyle of a block / InstanceDefinition, but I’m not sure if you can actually change it through this parameter since only the “get” function is documented:
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_DocObjects_InstanceDefinition_LayerStyle.htm
That might be a place to start.
