Default tolerance settings
What are the default tolerance settings in Rhino 7?
Is it possible to customize it?
I run Grasshopper headlessly on the server and do not create any Rhino documents.
Many thanks in advance,
Filip
The tolerance of Rhino files in RIR usually remains consistent with that of Revit. Here are some explanations, and I hope they will be helpful to you,
https://www.rhino3d.com/inside/revit/1.0/guides/rir-grasshopper#tolerances
Hi :sunglasses:
This isn’t a Rhino.Inside.Revit question. It’s a Rhino.Inside question. It’s headless…
-w
