I’ve just installed VisualARQ 3.10 and want to play around creating a steel beam. According to the screenshots I saw, there should be a predefined database of different steel profiles already.
Mine is completely empty.
Should I do a reinstall, or did I miss something during installation?
Hi @Andreas_Zieritz, You can open a new file from a VisualARQ template, export the desired styles (all, if you want) with the vaStylesExport command to a .val file, and then, import this .val file into the existing document with the vaStylesImport command.
In this directory you will find the .val files of VisualARQ object styles library that comes with the templates: Rhino 8: C:\Program Files\AsuniCAD\VisualARQ 3\RHINO8\en-US\Libraries
