Default Print Colour to By Display, All Objects
Output Colour, at the printing stage, By Display is obviously really handy.
What I often need is Print Widths + Display Colours at the same time - this is what changing all the Print:: By Display helps with.
Is there a way to script it? In rhinoscriptsyntax I don’t see a By Display option :frowning: https://developer.rhino3d.com/api/RhinoScriptSyntax/#object-ObjectPrintColorSource Maybe it’s possibe in Rhinocommon?
But I guess for all new objects the default will still be ByLayer printing?
Controlling ByDisplay , by layer, would be cool maybe?
Hi @Jonathan_Hutchinson1,
Use ObjectAttributes.PlotColorSource.
– Dale
Hmm… okay, I don’t quite understand the documentation well enough.
Right, I got this though. https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_DocObjects_ObjectPlotColorSource.htm
ObjectAttributes.PlotColorSource Property says there are three ways to set but only describes two.
import Rhino
#       Rhino.DocObjects.ObjectAttributes.PlotColorSource
#       Rhino.DocObjects.ObjectAttributes.GetType( )
string = "Prompting for Selection"
bool = False
filter  = Rhino.DocObjects.ObjectType.Curve
object = Rhino.Input.RhinoGet.GetOneObject(string, bool, filter)
attributes = Rhino.DocObjects.ObjectAttributes()
print attributes
#   Rhino.Input.Custom.GetObject.Get()
#   Rhino.Input.Custom.GetObject.GetMultiple()
# Set to By Display (2) ObjectPlotColorSource
attributes = Rhino.DocObjects.ObjectAttributes.ColorSource.Info
Rhino.DocObjects.ObjectPlotColorSource.PlotColorFromDisplay
#   print object.PlotColour
I’ll try again once I’ve had a bit more practice.
Try this:
import Rhino
import scriptcontext
def test_object_print_color():
    filter = Rhino.DocObjects.ObjectType.AnyObject
    rc, objrefs = Rhino.Input.RhinoGet.GetMultipleObjects("Select objects", False, filter)
    if rc != Rhino.Commands.Result.Success: return rc
    if not objrefs: return Rhino.Commands.Result.Failure
    for objref in objrefs:
        rh_obj = objref.Object()
        if rh_obj:
            if rh_obj.Attributes.PlotColorSource != Rhino.DocObjects.ObjectPlotColorSource.PlotColorFromDisplay:
                atts = rh_obj.Attributes.Duplicate()
                atts.PlotColorSource = Rhino.DocObjects.ObjectPlotColorSource.PlotColorFromDisplay
                scriptcontext.doc.Objects.ModifyAttributes(objref, atts, True)
    scriptcontext.doc.Views.Redraw()
    return Rhino.Commands.Result.Success
if __name__=="__main__":
– Dale
