when i open rhino 7 i only get one default black layer. is there a way to make it so when you open rhino 7 multiple color layers you added in there automatically open when you start a new project? thats layer question one.
make your layers then save as a new template
how do you save as a new templete?
File>Save as Template…
is there a rhino icon you can change the new template to so it looks like the original one?
not sure what you mean by that. If you mean the image you see of the Rhino file itself: Rhino saves the active viewport as thumbnail image.
ugh i thought i was being cool but now all rhino files are only opening with
what i set the OPENS WITH in the properties to.Categorized.
Please assign your new messages to the appropriate category so the right people are more likely to see it.
Thanks
when i press continue it goes away and i can model
when i click the help link you post it takes me to the help page describing whats going on but it doesnt explain the fix
@327mhg
Well, where are the missing images? Were they with the original file? Did you delete them?
SEARCH= Search results for 'missing image files' - McNeel Forum
Hello - it looks like your default template is one made for matrix - you can pick a different startup template, or with this one, if you delete all the materials that have missing textures then SaveAsTemplate
you should be all set.
Hi Pascal, my goal was to be able to have the same layers in a rhino 6 template as i do in the matrix rhino 5.
