Is it possible to change V5s’ default extrude straight command to create (poly)surfaces rather than extrusion objects?
Hi Matt,
The command _UseExtrusions can set that behaviour:
http://docs.mcneel.com/rhino/5/help/en-us/commands/useextrusions.htm
-Willem
@margaret according to the online help, this command is nowhere to be found in the GUI should that not be somewhere, to make it more discoverable for the user?
-Willem
Thanks Willem. As a said ‘User’, I had a long look through the help files but could find very little on the subject.
You only find it if you type “Extrusions” in the index box…
–Mitch
Yes, it should be. It’s on the list.
~M Becker
