Default CAM Imperial DXF Export Settings?
I do CNC routing on various machines and met one that didn’t like Rhino, kept turning my arcs into faceted segments. I eventually figured out the problem but did some unnecessary damage to my CAM Imperial default settings in the process. Now everything is coming out funky and I’m just flipping switches like a monkey.
Could someone please screen grab both tabs of the export window for me?
HTH
Thanks Wim, could I get the other tab as well, curves?
Sorry about that!
@BrianJ I have the same problem as Weston. While testing we changed settings for most dxf export defaults. Is there a way to get all the defaults back? Thanks.
If you go to C:\Users[YOUR USER NAME]\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\AutoCAD file export , you’ll find an xml file you can delete and then restart Rhino to reset the schemes. If you can’t get to App Data use " %AppData% " in a file explorer to locate the directory.
In the future, if you make a copy of the settings (SaveAs) you can flip switches like a monkey all you want and then you have the original to fall back on when you flip the wrong one.
