Deer Antlers with SubD
I am designing a couple of deer antlers with the SubD commands.
I would like to know if there is any command able to smooth the 2 SubD surfaces highlighted in picture.
Ideally I would like to have 1 continuous surface obtained from the 2.
Thank you!
Hello - probably the simplest is to set up a skeleton of lines and use MultiPipe on those, then adjust here and there to get the tapering.
Thanks Pascal! I indeed worked with pipes then I did bridge subD and fill subD hole.
Picture of the 3D print, it came out really smooth :slight_smile:
