This is my current work, I am essentially trying to make the arches taller at the apex of the curve and I am having trouble with my sweep generating the desired geometry. Any tips on how to solve this would be greatly appreciated.
you should share your file, not just the screenshot!
PARAMETRIC DOME SCRIPT.gh (13.1 KB)
My apologies, here is the full script!
This is a good approach!
Thanks, @Isabella_Robledo_Rom
I checked itâI like your approach. I didnât know about the kaleidoscope component! OffsetCrvLoose + MoveAwayFrom are good allies here.
See if this helps:
PARAMETRIC DOME SCRIPT.gh (19.1 KB)
(Iâm sure you can choose other approaches for the âapexâ increase, but I went with your idea of graph mapper, just opted for another graph)
Thank you so much, this is the solution I ended up going with.
