Hi all,
I am looking for a command that deconstruct a matrix in rhinocommon like the grasshopper componant deconstruct matrix.
I could not find that in the matrix class. Is there something similar ?.
Cheers,
Ghaith
Hi all,
Cheers,
Ghaith
Hi @tish.ghaith,
I haven’t tested this. But this should be the C# equivalent:
public static double[] DeconstructMatrix(
Rhino.Geometry.Matrix matrix,
out int rowCount,
out int colCount
rowCount = colCount = 0;
if (null == matrix)
throw new System.ArgumentNullException(nameof(matrix));
rowCount = matrix.RowCount;
colCount = matrix.ColumnCount;
var values = new System.Collections.Generic.List<double>(rowCount * colCount);
for (var r = 0; r < rowCount; r++)
for (var c = 0; c < colCount; c++)
values.Add(matrix[r, c]);
return values.ToArray();
– Dale
Many Thanks!. It looks like we can access the matrix like if it is a list of lists already. The matrix type basically inherits from List Type or ? I have seen it inherits from Idisposable pattern. such things I find a bit confusing in the documentatoin. It might be helpful maybe if we can tell from the description the behavioure of the objects. “Just a suggestion”
Hi @tish.ghaith,
When you see a RhinoCommon class that inherits from IDisposible, then the class is a wrapper for one Rhino’s core SDK class., ON_Matrix in this case.
– Dale
