Decals Toggled Off?
I’m working with a rhino file that has decals applied to some surfaces. My coworker can open the file and see the decals, but if I open the same file I can’t see the decals. We’re both using the same Rendered view, so I’m wondering if there’s a deep setting in my rhino that I may have toggled off at some point that’s preventing decals from showing. I’ve dug through the settings and compared both machines but I don’t see anything that’s different. Anyone experience this before?
can you share the file here?
if not can you send it to tech@mcneel.com?
Here’s a copy of the 3dm file with the images being used for decals, as well as screenshots from both PC’s showing the same file.
Decal Debug.zip (2.0 MB)
hmmm. pops right open with decals intact in my v8 and v9 beta.
can you please run the systeminfo command in Rhino on both the good machine and the bad one and post here so we can compare hardware?
Here’s the system info for both machines. PC1 is the one that cannot see the decals.
SystemInfo PC1.txt (3.0 KB)
SystemInfo PC2.txt (2.4 KB)
I had Claude.ai run a comparison/evaluation on these as well, and it recommended adjusting the OpenGL level in Options>View>OpenGL. I tried all options, restarting Rhino each time, and at Max OpenGL Available the decals appear. That seemed to fix my issue, but it’s still a weird situation that could be looked into for Rhino 9
ah… that’ll do it… you have to be running the max open gl your card can handle or you will get all sorts of display and rendering issues.
in most cases this is slider all the way to the right/ max setting.
also you are 12 releases behind on rhino 8… please run help>check for updates to get the current release.
Can do, thanks for your help!
