Decal/Surface Mapping
Hi Everyone,
I have a polysurface that I would like to map a texture/decal to certain surfaces without exploding the model. Is it possible to do either via sub selection, scripting or another method?
Thanks for your help!
Andrew
Hi Andrew - you can assign planar, box, cylindrical mapping in the object Properties, as well as ‘Custom’ which allows you to create a surface that conforms as you like to the polysurface and use it as a mapping projection source.
Sub-object material assignment is slated for v6
