Is there a way to have decal work on the terrain object?
for example that i want to display mapbox sat image on it
i want to apply this on modeled train from scratch on location.
not imported from mapbox.
Hi, look for the location of the terrain that you have generated, on the map in the import terrain dialogue box or importing terrain (Earth scan), there are 2 options you can choose both, or one: 3D Mesh with satellite image, or 3D Terrain. You can even select both and import both of them. If you already have generated a terrain, try to import just the mesh with a satellite image, visible in rendered mode.
Another workaround is if you have a satellite image, and assign it as a texture to the terrain.
Ok i was able to use a texture onto the terrain, and manually find the right scaling to fit it on top of the terrain as you suggested. (i generated the terrain with DEM)
i was able to do this for this project but Iām not sure if it always be so easy to get the right projection onto the terrain.
im guessing it will be to hard to provide a feature that would pull in the image from mapbox as working as import from earthscan?
Thank you for replying.
We have added your request to the wish list. Thanks.
