Аdd a picture
How to repeat add a picture, but only from a grasshopper and on the surface?
Import image unfortunately preserves the mesh ((
There is no 3d object as image in Grasshopper, indeed in Rhino it is a surface with a Picture material.
If you want to do that you will need to make a material with an image and apply the image to a surface object (surface object with same proportion as the image).
You can use this component from Human plugin
This one from Parakeet
This one from Nautilus
Do you have access to rhino 9 WIP?
Hi Martin, yes there is
Try importing a picture material. The component is in the Grasshopper Rhino tab under materials.
