David rutten Video
Hello, @DavidRutten what was the process behind this video. Where i can found the New Imaging Component
Thanks,
The imaging components are available via Yak. Type _PackageManager in the Rhino command line and install the ‘imaging-library’.
Thank you so much.
Hello, @DavidRutten
When i type this. I got an unknown command
TestPackageManager
Hello, @nathanletwory
Still the error remains same. I’m using rhino 6 SR8
I don’t recall when TestPackageManager was introduced, but 6SR8 is rather old. You may want to update to the latest SR
Thank you @nathanletwory I’ll definitely update it.
This command not working. My rhino version 6 SR14 @nathanletwory
_TestPackageManager
This also not working. Any other. Even I’m using latest rhino 6 version
It is Windows OS only, are you on a mac?
You can use the Yak command line:
"C:\Program Files\Rhino 6\System\Yak.exe" install imaging-library
See https://developer.rhino3d.com/guides/yak/yak-cli-reference/ for more info.
Regards
Jeremy
Also _TestPackageManager does not autocomplete when typed in Rhino, you have to type the whole thing and hit return.
Jeremy
Windows
Nope, works fine in Rhino 6 for mac!
So how do these components work? Could you show us an example please?
I was able to create 1px size image a while ago :wink:
Hello @DavidRutten ,
Could please Update with some examples for your imaging components. We are waiting from 2019.
@DavidRutten
Edit 1: is there any special reason for not sharing examples/ tutorials about it and simply boycotting our requests or else you made that only for you.
Image Example.gh (20.3 KB)
yields:
