Blocks and Named CPlanes solve two different problems, not the same one — and the split matters more than it looks.
A Named CPlane is a reference, not an object. It lives in the 3dm’s view table so you can snap back to an orientation inside Rhino. It has no representation in STEP or IGES at all — there is no “named construction plane” entity in either format. If your operation-2 datum only exists as a Named CPlane, it is invisible the moment the file leaves Rhino, and whoever opens the STEP in a CAM or CMM package has no way to recover it. That’s the trap in “keep the primary solid, keep the datums as CPlanes” — the datums are the one thing that has to survive the export, and CPlanes are the one thing guaranteed not to.
A block instance is real document geometry — an instance definition plus a transform, part of the model, not a UI reference. That’s exactly the right tool for what you actually need it for: representing “operation 1” and “operation 2” as two placed instances of the same nominal solid without ever duplicating or baking vertices. Moving the block only moves the transform; the underlying definition stays untouched and revertible. So: yes, blocks over duplicate-and-transform for the fixture bookkeeping — but that’s an internal Rhino convenience, and it shouldn’t be asked to do double duty as the thing that carries the datum out to inspection.
What has to travel with the file has to be baked as geometry, on its own layer, before export. Sealing-face datum, port axes, minimum-wall check curves — turn each into an actual small reference object (a trimmed plane, a short axis line, a point) that a STEP/IGES reader will show as geometry, because that’s the only representation every downstream tool agrees on. Your INSPECTION and CHANNEL_KEEP_OUT layers from the neighbouring thread are the right instinct; the layer name just isn’t a guarantee by itself. Layers are typically carried as presentation/organizational data in STEP, and how faithfully that survives depends on the importing software’s translator, not on Rhino. Before trusting the pipeline, run one smoke test: export a tiny reference cube per layer with distinct names, reopen it in the actual downstream CMM/CAM package your shop uses, and see literally what survives — layer name, layer visibility, object user text, all three can behave differently on the same round trip.
For the metadata itself (operation number, machining allowance, revision) I’d attach it as object User Text (SetUserText) directly on the datum geometry rather than only encoding it in the layer name. User text travels with the specific object even if someone re-organizes layers downstream, whereas a layer name is one rename away from losing its meaning. It’s still not guaranteed across every STEP importer — which is exactly why the reference geometry plus the drawing PDF, the pattern you’re already using in the neighbouring thread, is the right belt-and-suspenders: the geometry proves the datum, the PDF proves what it means if the metadata gets stripped.
One question that changes the whole approach: is the downstream side reading plain STEP (AP203/214), or does your CMM/CAM chain support AP242? AP242 carries PMI — structured datum and tolerance annotations — as actual semantic data, not just geometry a human has to reinterpret. If AP242 is available on the receiving end, the honest fix isn’t a clever Rhino layer scheme at all, it’s exporting the datum information as PMI directly, and the geometry-plus-layers approach above becomes the fallback for tools that don’t read it.
I work as a contractor on the geometry/automation side of production tooling — closest public example is a layout planner built for a racking manufacturer, where the customer sets room constraints and the plan rebuilds live under them rather than being redrawn by hand: Standes — 3D shelving configurator · Artur Smirnov
