DataInput and DataOutput in python
Hello gentlemen.
Does anyone have experience with creating DataInput and DataOutput with python?
I have a problem writing in the command where to save the file and which data to put in the file.
Thank you :slight_smile:
Not directly, but you might instead implement a native Python module to write/read data to/from disk. Depending on the data types, I usually implement the pickle or json modules:
There’s also the native shelve module, which seems to be functionally similar to structuring the data into as dictionary and pickling it (have not tried it myself though).
I’ve not tried it either, Python’s native File IO is sufficient for me too, even for .csv files.
But this looks useful - cheers. Isn’t ghpythonlib.components how you access Node In Code?
Unfortunately not every Grasshopper component works when called via Node In Code. There are thousands of them, and this is a “nice to have”, so you can’t blame the devs.
If you want to use them natively in Grasshopper, the best description I can find is: Can Two GrassHopper definitions communicate? - #12 by RIL
I’m able to create data with python , but i’m not able to read it …
They didn’t solve it there either.
