Hello
Please see image attached
I need to combine each 0;0 , 0;1; 0;2 and so on
I can do it manually, but i would have to write until 0;150
Is there a way to combine them?
They represent lenght, width and height of wood pieces, then i need to export them to excel with stream content
Thanks for your help
You can stream data from a panel into a *.csv file
Looks to me like a simple Merge would accomplish the task, without any Tree Branch components. You might need a Flip Matrix after Merge ?
Asking questions and getting answers is what this forum is all about. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions, but don’t think of them as rules and especially don’t think of them as guarantees.
1. Choose a descriptive title for your post
Don’t title your question Help! or I have a problem or Deadline tonight!, but actually describe the problem you are having.
2. Be s…
3. Attach minimal versions of all the relevant files
Merge did the job
I did not now that component would work on this
Thanks so much!
Thanks Martin
I was aware of that
Kind regards
Avoid passing data through text panels. Consider text panels as temporary and deletable.
Looking more closely (wish you had posted a GH file) , it looks to me like you could Merge the curves and have only one curve Length component?
