Boundry Surface.gh (64.7 KB)
For closed curves, why don’t we internally change the data structure before calculation?
The examples 1 and 2, both are grafted, but they exhibit a 3 times speed difference. Why is that?
Why is that?
And also see this.
Applying Boundary Surfaces
to a list of curves is different to when each curve is in a separate branch.
It checks the curves against each other for containment
Even though none of the curves in your example are actually contained within each other, when the items are in the same list it is still checking.
Thank you @DanielPiker.
