Data matching / Sweep problem
I’m working on a Gh definition of a curvy shape building. The main problem is about the structure. I want a complete control on depth and height of every post-beam, but the sweep doesn’t work (at all for some lines, badly for the other one…). Here’s attached the rhino + gh files. Any idea of what is not working out? Thanks !
Florent BIC.3dm (66.0 KB)
BIC.gh (24.3 KB)
Your data matches fine. The problem is your logic of the sections. Sweep won’t be able to figure that out.
Ok thanks! I’ll try in an other way then !
This could be a workaround for you.
BIC_re.gh (30.1 KB)
Indeed, a way more efficient script, thanks a lot for your help !!
