Hi there … so i’m trying to construct a NURBS curve with 4 points.
I thought that when you connect multiple inputs with the shift key that the resulting list is ordered in the order you connect the inputs … this works fine for the first 3 points (i connect the first point then shift connect the second and then the third):
but when i connect the fourth point suddenly the order changes:
i’ve been trying everything i could think of but cannot figure out why this happens or how to get the points in the order i need to construct the curve i want successfully. I’ve always used the shift-connect in order so far for a variety of things and have never run into this. As far as i can remember the order you connect things is the order the list comes out of the output.
When i try this out on an empty patch it works like expected and the points stay in the order i connect them to the nurbs curve component vertices input, so something in my patch must be the issue. Unfortunately i can’t share the whole patch here but am surprised that this happens at all … i thought a point was a point so i don’t understand what causes this. The first and last points (0 and 3) are just end points of a line but the second and 3rd (2 and 3) are points from a surface evaluation, i then flatten the inputs of the NURBS curve component.
what am i missing ?
