In the given screenshot, in the first scenario, when I input grafted elements of group 2 in concatenate, then every element of 1st group gets matched with 2nd group. This is understandable, as all elements of group one try to match with every branch of the grafted group 2.
In the second scenario, when both group 1 and 2 are grafted, why don’t every element of both groups (now individual branches) match with each other?
What should be the outcome?
Can u just type it down by hand?
U may need to duplicate some data first… Maybe a FlipMatrix is needed too…
or any other Tree-related-Stuff…
It strongly depends on what u are expecting…
First, branches match to branches
Then, items match to items.
Both branches and items use basically the same “matching” rules - effectively, “longest list” matching. So if you match 1 branch M with many branches N1-N6, it will match M to N1, M to N2, etc. If you have M1-M3 branches in one input, and N1-N3 branches in the second input, it will match M1 to N1, M2 to N2, and so on.
Then, once the branch associations have been made, it handles item matching within each branch match, in exactly the same way.
So this means when you graft both grp 1 and grp 2, it’s just going to match each branch with the corresponding branch in the other list. Each branch has only one item, so after that, it’s done!
Hope that helps explain a little bit; if theres a particular problem you’re trying to solve, try to explain it a little deeper and we can try to help
If you’re a beginner you might also benefit from this accompanying video tutorial I put together https://www.youtube.com/watch?v=MQKkiggh6vE - I explain a lot of these concepts in a little more detail in the real context of Grasshopper’s interface
This document is pure gold! Nowhere in this universe I have ever seen such simple explanation of data trees! @andheum . Thank you so much for this again.
