Hi, I have a file that I built once and worked fine before. Now I’m opening it to continue working on the model but I can’t generate the gh script. One of the components I was previously having trouble with but fixed is now telling me something else. It’s saying that data conversion from curves to line failed. I’m guessing this is an easy fix but I was also wondering why it happened if the file was working fine before. Thanks in advance.
The picture at the bottom is what I previously got and I’m now going to edit it a whole lot.
Hey thanks for the quick reply. I tried to re-do the script with the original model and it worked. That’s why I deleted the post but I just want to create honeycomb panels with the spheres I’m using. Anyways I’ll use these solutions if I encounter similar problems. I didn’t know what the curvepull component did and still don’t understand it. I just followed a tutorial https://www.youtube.com/watch?v=MsbyfC2usUk
Thanks a bunch
edit: wow, this creates the best honeycomb structure. I’d say almost perfect if some panels weren’t missing. How’d you get to manipulate the curve pull so that it doesn’t lean in one direction?
