Data conversion bug
Hi all.
I have a .gh project where a small script read data from a xls file, than the output is managed with vanilla GH components. The data is always treated as simple text.
Then, at this step, it is converted to a number:
but it fails when first loading the .gh file.
I tried to internalize the data, but the bug doesn’t occur in that case.
I can’t share the script or the xls file…
If I manually re-connect from C data param to C number param, the conversion is correct.
My guess is that, while the .gh load the first time, the xls reading script expire the document in a way that causes the number param to misbehave.
I can repeat this any amount of times, happens always.
Only once, the first time the .gh is opened.
After the first time, it never occurs again. I have to restart Rhino to replicate it again.
Do anyone know similar scenarios? Any ideas?
@DavidRutten @Gijs
just a stupid thought -but it happened to me dozens of times- when importing text that might come from different keyboard layout / languages, some characters might not be recognised correctly (I mean at ascii-table level)
last time I saw something like that was in this thread from a few weeks ago: Sorting a tree by the first element in a branch - #7 by inno
just out of curiosity I would try isolating that mysterious “.” while is still text, and replace it with a “.” typed from your keyboard, and see what happens
Inside my .xls reader I have a piece of code like this:
.ToString().Replace(',', '.');
…because in italy we use commas as decimal separator :upside_down_face:.
So the “dot” is forced to be the actual dot from my keyboard…
Even added a vanilla GH replace text:
The selected components were added manually after the .gh file is loaded.
Recomputing the whole definition or manually reconnecting solves it… as said.
Internalized, but as in the .gif, not really useful. Internalized data works fine.
conversion
conversion bug 2.gh (7.8 KB)
Code used here:
  private void RunScript(string txt, ref object R)
    if(txt.Contains(",")){
      txt.Replace(',', '.');
    if(txt.Contains(".")){
      R = Convert.ToDouble(txt);
    }else{
      R = txt;
Seems really like the dots have some sort of problem after the .xls reader compile the first time.
… but the unicode of the dot seems correct…
There is a possibility that a plugin (re-)sets the localization to your computers default during initialization. After recomputation the invariant localization is set again. So this could explain, the behavior during first execution. Usually non-American developers are more aware of this problem, that is why I doubt its coming from Grasshopper. You could try to disable as much plugins as possible and see if this solved it. Have your written the Excel deserializer?
Omg, yes! I was going crazy!
It is the same thing I were searching about now!
I didn’t know that.
I’m using OfficeOpenXml library, from EPPlusFree.dll and I wrote my c# script to load my .xls.
Yes, during the first run of the script (while it compile) I see numbers having decimals with commas, but just after that it switch back to normality.
Thank you!
I know where to search now…
