Hello, I’m having some troubles (hopefully not self-made(?)), using Hops.
I used to be able to use Hops, and worked with it regularely lately. I was trying to add some functionality to it, by allowing to export custom ironpython objects (which I didn’t succeed anyhow - maybe I’ll ask about that in another post).
I’m not sure, if I introduced the issue, which I’m encountering now by myself. I already tried to reinstall Rhino, Hops, dotnet, but the issue remains.
I would appreciate any idea on what I could try to resolve the issue.
[15:27:09 ERR] Connection id “0HN9URQNBI67I”, Request id “0HN9URQNBI67I:00000001”: An unhandled exception was thrown by the application.
System.Xml.XmlException: Data at the root level is invalid. Line 1, position 1.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.LoadXml(String xml)
at GH_IO.Serialization.GH_Archive.Deserialize_Xml(String xmlContent)
at compute.geometry.GrasshopperDefinition.ArchiveFromBase64String(String blob) in D:\BuildAgent\work\4852f584398a78e4\src\compute.geometry\GrasshopperDefinition.cs:line 1212
at compute.geometry.GrasshopperDefinition.FromBase64String(String data, Boolean cache) in D:\BuildAgent\work\4852f584398a78e4\src\compute.geometry\GrasshopperDefinition.cs:line 109
at compute.geometry.ResthopperEndpointsModule.GrasshopperSolveHelper(Schema input, String body, Stopwatch stopwatch, HttpContext ctx) in D:\BuildAgent\work\4852f584398a78e4\src\compute.geometry\ResthopperEndpoints.cs:line 70
at compute.geometry.ResthopperEndpointsModule.Grasshopper(HttpContext ctx) in D:\BuildAgent\work\4852f584398a78e4\src\compute.geometry\ResthopperEndpoints.cs:line 142
at Microsoft.AspNetCore.Routing.EndpointMiddleware.g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)
