In the past, I used to use the ‘PDF Creator’ printer in order to batch output layouts as PDF, through scripting.
It seems that the dashed version of ‘Print’ is not working properly any more: if I print a test layout with ‘Print’, the preview window is displayed and the PDF is correctly generated: PDFCreator_normal.pdf (3.6 KB)
If I run '-Print G <output path> ', the output PDF is corrupted: PDFCreator_dashed.pdf (15.8 KB)
I also tried some other PDF printers:
Rhino PDF:
– normal ‘Print’ works fine
– dashed ‘Print’ will open a window to choose the pdf output path > I don’t want to work with GUI, but directly specify the output path in the console…
Microsoft Print to PDF
– works fine with both commands, but that printer seems to be really limited in terms of paper formats…
If someone have any clue about this, I’ll be really thankful…
