Dashed Linetype inside Block not displaying Correctly
Is there any hidden setting I need to tick for this to work as expected? I can’t imagine someone wanting this to be the default behavior.
block test.3dm (87.5 KB)
The linetypes are scaling with the block. I’ve added your report to the existing issue RH-82139. Thanks for reporting.
Thank you!
I actually did not realize the original block size was so big, probably because it was done in mm in cad.
Is there a way to redefine this size as the current/default block size, without having the instances change?
For instance if the block instance has been scaled by a factor of 0.01, how can one update the block definition to this size, and all instances that have scale factor of 0.01 now have the scale factor back to 1.
  1. Place an instance of your door Block at 0,0
  2. Edit the Block
  3. Scale from 0,0 by a factor of .001
  4. Then run BlockResetScale on all previously placed instances.
