Dashed line end points
Is there any way to halve the length of the first and last line within a dashed line type?
When two end points meet the dashed line breaks the continuity of the flow. Halving the dashed lengths at the end points won’t effect corners, you’d still see a ‘full’ dash and the corners would be marked.
Andy
Hi Andy - try this, assuming that is a polycurve with multiple segments joined at the ‘longs’:
Turn on control points for the curve, select one and nudge it, and then nudge it back. This will change the curve from a polycurve to a NURBs curve and should, I think, eliminate the start-stop of the pattern.
https://mcneel.myjetbrains.com/youtrack/issue/RH-36465
Ah! That’s fixed it, thanks!
Andy
