Dark mode button color bug
There’s a bug where I can’t edit the color.
I’m trying to make the white part red – wont work, just stays black.
So much for dreaming about modding the tool pallets again. :sleepy:
Hmmm this version worked though I think:
Must be a ‘darkmode’ image bug.
Can you share the SVG file you are trying to edit?
Yeah, I’m tryna figure that out, it’s kinda hard to find cause the containers are in one spot and the toolbars are in another spot.
Basically this is the directory:
Edit
Control Points >
Select Control Points >
I’d like to add color cause I like using red for U and green for V. And visually that would be better for me while I’m clicking buttons working on surfaces.
finally found pallet again.
select u
here’s the svg thing I saved yesterday while tryna figure it out.
I wasn’t sure if the default one was protected, although the light one was editable but the dark one was not.
doesn’t look like it pasted correctly lol
maybe zipping it will paste better:
select u dark(cant make red).zip (2.0 KB)
I just overwrote the darkmode versions with the lightmode versions as a workaround.
