Cylinder is getting in two separate faces
In this model, hole is getting into two faces. How can I get whole cylinder as single face.
Regards,
Bhavita
in the other post of yours, I gave you the advice to look for Edges that are Circles. That being said, you can test all the Brep faces to see if they are Cylinders. Once you collect them all you can try to Join them. As a result, you should get your Cylinders (as Breps). If you want to test if those Breps are then Cylinders, you can then also try to examine the Edges of those Breps to determine if they are Circles, or you could check if both faces (assuming that now they will have 2 faces) are Cylinders.
