Cyclops CUDA Library not found
Hi, I am getting an error that cant load CUDA library. I have been using the plugin before so not such which dependency broke. is there something in the special folders I can check to re stablish the connection to the CUDA library?
Hi @Roncal_Andres ,
Thanks for posting a separate thread.
I’m not sure why this is happening but my assumption would be that the program can’t find or access the CUDA dlls. Have you tried reinstalling the Nvidia driver?
Yeah i did, I figured maybe thats what broke the connection as it was working before. But not sure what else I could check
If you go into Rhino’s document properties → Rhino Render, do you see the CUDA tab there? If you do, what color is the dot?
Here’s what mine looks like:
Hi, thanks for sharing. For me is not even showing the GPU there, where should I go to try add it?
@Roncal_Andres if you open the task manager and go to the performance tab, can you see your Nvidia GPU there?
Hi, yes, the GPU shows in task manager.
I am updating to the latest drivers, maybe then it will show in rhino? or im hoping.
ok the drivers worked. The light is yellow tho, but the plugin now recognizes the CUDA library. thanks a lot for the help tho :folded_hands:
