Cycles Rendering: Lighting Control
How can I disable ALL ambient lights/HDRI/etc. when rendering, except for specific lights or emissive materials that I add to the scene? Most of the time I’ll get better results using environments / HDRI’s etc., but for certain things I can see a benefit to having complete control. I think there must be some additional settings I’m missing, because I have not figured out how to turn everything off. Anyone know how to do this?
Hello- disable Skylight in the Lights panel. Note if you have no lights at all - and emiisive materials do not count as lights - you get a default over-the-left-shoulder light. To force this off, add a point light inside a box or set its falloff to inverse square and intensity way down.
In Rhino 8 emissive materials do count as lights.
Thank you, that seems to have done the trick!
