Hi @nathanletwory I had to roll back to the previous WIP as the one I installed yesterday ignores making shadows.
By the way here is a small material test on what I am working on:
A bug was introduced in the underlying display pipeline. I fixed it earlier today.
https://mcneel.myjetbrains.com/youtrack/issue/RH-41477
Essentially the pipeline kept telling Raytraced to render without shadows.
Good, thanks!
I noticed that rectangular lights have object properties for “cast shadows” and “recieve shadows” and that doesn’t really make sense, so maybe these should be removed.
Hi Jorgen - I found you can kick shadows off again by un-checking and re-checking Shadows in the Display panel. You need to do it from time to time …
Hi, thanks, I just uninstalled, cleaned the regestry and reinstalled the previous build, so I’ll stick with this one until next week.
