Rhino (6.0.16054.12001, 23.02.2016)
German language in the OS
Cycles doesn’t load.
While it did and worked in earlier releases.
RhinoCycles uses open source libraries that are available at www.rhino3d.com/opensource
RhinoCycles 6.0.16054.12001 Error occured loading plug-in
Details:
Die DLL “ccycles.dll”: Das angegebene Modul wurde nicht gefunden. (Ausnahme von HRESULT: 0x8007007E) kann nicht geladen werden.
I find that the 3/15/2016 WIP produces the same “Unable to load Cycles” (paraphrased) message that the last two builds produced on startup.
Is there something else beyond just installing the WIP that I need to be aware of to get it to work?
Note though that the render window plug-in isn’t that much tested, because it isn’t bundled with Rhino WIP (yet). If and when the plug-in stops working check the above link for newer releases - and if there aren’t any poke me.
