Cycles Backdrop soid color/gradient not selectable [Solved]
WIP rel 6.0.17283.9031, 2017/10/10
As in title.
Uncheck Transparent Background.
thanks…
Short titles are better, with the kind of problem mentioned. This is to help readers to chose whether to read the details or not. Long texts is exactly what a title is meant to replace.
“Cycles backdrop solid color/gradient not selectable” gives the clue and enables readers to pick or skip. Adding [Solved] at the end is also informative without messing up the title list.
// Rolf
Should I remove the WIP ver to make it shorter? and change as just solved?
Let me know what’s better.
WIP keeps changing so thought it would be good to put the info in the title.
(maybe just the date as that is more practical.)
Since WIP is the category it can be left out.
WIP-bugs are handled quickly and new versions comin out all the time, so they are typically not very “long lived” anyway.
In my opinion “[Solved]” at the end is good enough.
// Rolf
Ok, will update no problem.
