Grouping Cycle Selection Issue.3dm (31.2 KB)
Part 1: The two lines on the left are part of a group. There is a third line on top of the leftmost line. If you click on the left line it cycles through the possible selections: the group or the since line.
Part 2: The right 3 lines contain two groups. One group is the left most 2 lines of the 3 and the other group is the right most 2 lines of the 3. If you click on the left or the right lines it shows the group memberships.
Issue / Feature Change:
When you click on the middle line it automatically selects the group that the line was last associated with. The user does not even know it’s a member of a second group. In my opinion, it should cycle through the group selections just like the left most 2 lines in Part 1. This would make the user aware that the object is part of multiple groups and it allows the user to select the group they want.
