Cut Plate Marking
How can one add lines to the surface connections / fit-up when using unroll? Trying to add marking lines for weld up cross beams.
When running the UnrollSrf command, you can select these lines. For more details, please refer to the introduction in Help.
unrollsrf
I had tried that but was not getting the lines to transfer. After I copied the lines I projected they to the Cplane, repaired the lines and than projected the lines back to the surface, it appeared to work after that process. I also grouped the lines.
Could you please share this .3dm file? Thank you.
