Hi, i am wondering, is there any function that i can add to cut solids selecting 3 points that define a cutting plane?
Thank you
Thank you
not automatically, but you can do it in two steps.
plane>3pts make you plane
then Boolean split using the plane.
Use IPlane with 3Point option
To Boolean split an object based on three points
BooleanSplit
Select the objects to be split.
When prompted for “Select cutting object” type IPlane
Select 3Point option
Select the 3 points
Complete
To Trim an object based on three points:
Trim
Select the objects to be trimmed.
When prompted for “Select trimming object” type IPlane
Select the 3 points
Complete
To split an object based on three points:
Split
Select the 3 points
Complete
HI, thx for your response, yes but for that i need to create a plane, then delete i think it’s not very smooth, but i think david cockey made a good response check it out ![]()
Thank you !
