I am trying to create this illustration in grasshopper and wanted to prick some else’s brain. It is a cut and fill map for altering topography.
Screenshots show some iterations I have made so far but none have turned out so far.
The goal is to create a surface in the difference of the two sets of curves.
I tried other methods such as loft, edge curves, ruled surface, etc.
It almost works: The “Cut” side/surface works but not the “Cut” side. Also this only works if I isolate one set of Existing + New lines. It goes bonkers if you set multiple curves.
