I am attempting to implement custom grips on Extrusions following the example:
SampleCsRectangleGrips
When I modified the code (see below) to return an Extrusion, I am expecting a solid Extrusion but a Surface is added to document instead. Is there a reason why this should happen?
T
/// <summary>
/// CustomObjectGrips override
/// </summary>
protected override GeometryBase NewGeometry()
UpdateGrips();
if (GripsMoved && m_draw_rectangle)
// Modified code to return Extrusion created from modified rectangle.
return Extrusion.Create(new PolylineCurve(m_active_rectangle), 100.0, true);
return null;
