CustomMeshObject OnDraw method problem with Rhino Sun light ON
I have a strange problem.
The plugin creates its own CustomMesh and overwrites the OnDraw method.
Inside OnDraw the plugin draws 1 box. Works fine.
But if I change the viewport mode to “Rendered”, and I turn On Rhino Sun light, it draws two boxes:
Like this:
If I move around the viewport, the intentionally drawn box follows the viewport orientation change as it should. But not the other box.
But if I change the Sun location, the orientation of the other box changes. So it is linked somehow to the Sun, but I don’t understand why.
Any idea?
Márton
Hi @marton.parlagh,
Any chance you can throw together a simple sample that allows us to repeat this here?
Thanks,
– Dale
Here is a simple code:
namespace TestCommands
   public class TestCustMesh : Rhino.Commands.Command
      public override string EnglishName => "TestCustMesh";
      protected override Rhino.Commands.Result RunCommand(Rhino.RhinoDoc doc, Rhino.Commands.RunMode mode)
         var m = Rhino.Geometry.Mesh.CreateFromBox(new Rhino.Geometry.BoundingBox(Rhino.Geometry.Point3d.Origin, new Rhino.Geometry.Point3d(10, 10, 10)), 2, 2, 2);
         TestMeshObject mesObj = new TestMeshObject(m);
         doc.Objects.AddRhinoObject(mesObj);
         return Rhino.Commands.Result.Success;
      public class TestMeshObject : Rhino.DocObjects.Custom.CustomMeshObject
         public TestMeshObject(Rhino.Geometry.Mesh m) : base(m)  {}
         public TestMeshObject()
            // required
         protected override void OnDraw(Rhino.Display.DrawEventArgs e)
            e.Display.DrawBox(MeshGeometry.GetBoundingBox(true), System.Drawing.Color.Red);
            //In case we return here (without calling base.OnDraw(e)), this strange effect is more visible
            //If base.OnDraw(e) was called, we have to click select/unselect inside the viewport to see this.
            //return;
            base.OnDraw(e);
When you un-comment the line with //return before base.OnDraw(e), you can see this problem easier. Otherwise you have to select/unselect the object to see it.
Steps:
  1. new scene
  2. call command TestCustMesh
  3. change viewport to “Rendered”
  4. Sun panel → turn ON sun
  5. click select/unselect object
Hello Dale,
Were you able to reproduce it?
I have another strange effect with CustomObject onDraw method.
This one happens in case viewport mode is “Rendered”. (In this case sun on/off doesn’t matter)
I use
e.Display.DrawMeshShaded(…)
So viewport is rendered and object is not selected:
This looks ok.
But if I select the object
The object is not drawn in normal shaded mode, but I can see the background environment image through it (or overlayed on it?).
Márton
Hi @marton.parlagh,
This seems to work better:
  base.OnDraw(e);
  if (e.Display.DrawingWires)
    e.Display.DrawBox(MeshGeometry.GetBoundingBox(true), Color.Red);
– Dale
Ohhh thanks!!!
I was drawing at the wrong pipeline state. - OK
It Works!
Thanks,
Márton
