I have some customBrepObjects (some beams) which work perfectly well, except when I execute make2D on this object. The layerIndex of the customBrepObject is modified, but it’s only visible through Rhinocommon, in Rhino UI the object is still on the good layer.
here is my code :
Public Class CustomBrepObjectTest
Inherits Custom.CustomBrepObject
Public Sub New()
MyBase.New()
End Sub
Public Sub New(b As Brep)
MyBase.New(b)
End Sub
Public Overrides Function ShortDescription(plural As Boolean) As String
If plural Then
Return "CustomBrepObjects"
Else
Return "CustomBrepObject"
End If
End Function
End Class
I call this function from a command :
Private Function TestCustomBrepObject(doc As RhinoDoc) As Result
Dim filter As ObjectType = Rhino.DocObjects.ObjectType.Brep
Dim objref As Rhino.DocObjects.ObjRef = Nothing
Dim rc As Result = Rhino.Input.RhinoGet.GetOneObject("Select brep to test", False, filter, objref)
If rc <> Rhino.Commands.Result.Success Then Return rc
Dim test = New CustomBrepObjectTest(objref.Brep)
doc.Objects.Replace(objref, test)
Return Rhino.Commands.Result.Success
End Function
Yes I can repeat the issue by running the TestCustomBrepObject, and then manualy running Make2D on the CustomBrepObject with the option Properties=ByOutputLayer.
Here is function that repeat the issue, and does not involve manual operations:
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
Const filter As ObjectType = Rhino.DocObjects.ObjectType.Brep
Dim rc As Result = Rhino.Input.RhinoGet.GetOneObject("Select breps to test", False, filter, objref)
Return rc
End If
Dim LastLayerIndex = objref.Object.Attributes.LayerIndex
doc.Objects.Select(objref)
RhinoApp.RunScript("_-Make2D P B Enter", True)
Dim newLayerIndex = objref.Object.Attributes.LayerIndex
If LastLayerIndex <> newLayerIndex Then
RhinoApp.WriteLine("Test Failed")
Return Rhino.Commands.Result.Failure
Else
RhinoApp.WriteLine("Test Passed")
End If
End function
When you replace an object, then any reference, or ObjRef, to it becomes obsolete, and you’ll need to reacquire the object to proceed.
For example:
Const filter As ObjectType = ObjectType.Brep
Dim objref As ObjRef = Nothing
Dim rc As Result = RhinoGet.GetOneObject("Select breps to test", False, filter, objref)
If rc <> Result.Success Then
Return rc
End If
Dim rhObject As RhinoObject = objref.Object()
If rhObject Is Nothing Then
Return Result.Failure
End If
Dim objectId As Guid = rhObject.Id
Dim layerIndex = rhObject.Attributes.LayerIndex
' TODO: replace object here
' Reacquire...
rhObject = doc.Objects.FindId(objectId)
If rhObject IsNot Nothing Then
Dim newLayerIndex = rhObject.Attributes.LayerIndex
If layerIndex <> newLayerIndex Then
Else
End If
End If
Return Result.Success
End Function
Even if I reacquire the object to proceed the test failed :
If rhObject Is Nothing Then Return Result.Failure
doc.Objects.Select(objectId)
RhinoApp.RunScript("_-Make2D P B _Enter", True)
Else
End If
End Function
Hi Dale, I’m sorry to bring up my issue again two years later. I’m still experiencing the same problem, and so are my colleagues. Could you try to reproduce the bug?
