Custom viewstyle fails to render in layout on latest Service Release
Well… me again.
I’ve spent some time figuring out how to create a custom ViewStyle with hard shadows (but in a light gray tone). I made a copy of Arctic and tweaked a few parameters, one of which was the gamma output to get the soft gray look I needed.
I was satisfied as it was ok for my needs.. everything was working fine, until I updated Rhino today.
Now the problem is that this ViewStyle is not rendering correctly inside a detail view (it was working before the Rhino update).
Since I’ve also been chasing a few other Rhino bugs today, I’m not sure whether I changed something accidentally or if this is related to the update.
Any help would be highly appreciated. (Also, if possible, a link to download a previous service release.)
System info at the end of this message
linear workflow.3dm (142.9 KB)
Sombras Grises sobre Blanco.ini (14.4 KB)
Rhino 8 SR29 2026-2-10 (Rhino 8, 8.29.26041.10001, Git hash:master @ 6f4761d87df45e886dd6b32508dff6a4c7e45f29)
License type: Educational, build 2026-02-10
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.14
Primary display: AMD Radeon™ 780M (AMD) Memory: 1GB, Driver date: 6-27-2023 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-7-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.97
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-7-2025
Driver Version: 32.0.15.8097
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\mutar\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\25.3.0.0\bella_rhino.rhp “Bella” 25.3.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.29.26041.10001
Im also having the same issue in:
Version 8 SR29
(8.29.26063.11001, 2026-03-04)
I only have the local installers until 8.29, so i cant backtrack and test in which release the function broke.
FYI, i managed to downgrade to SR27, and the problem went away. So, somewhere between SR27 and SR29 the glitch happened.
thank you Jonas.
My workaround was to setup differently my viewstyle.. messign up less with the gamma values.. and just using a gray ambient color. While this may work for exactly this need of the gray shadows.. I amm not sure of what would happen with other custom viewstyles where saturation or brightness or any other value was custom setup… Thank you for the advice of downgrading to SR27.
