Can someone give me a simple example how can I create custom type to come out of GH_Python component and then another GH_Python which is accepting only that custom type?
Is this possible to implement from within grasshopper or do I have to do this by setting up a VisualStudio project?
Simple example could be just a box that passes itself and its volume as a single stream of data (a custom type) to another component.
I canât answer to python, but for C# only part of this is possible.
You can create a new type inside a script component which implements IGH_Goo or one of its derived types/interfaces. This type will be treated by Grasshopper the way it treats all data. Provided you wrote code for it, this type can be baked, previewed, converted into other types, formatted.
It will not be possible however to deserialize the data, as Grasshopper wonât know where to start looking for the class when it is asked to read one of these in from a file.
The problem is that a different script component wonât have access to the same type definition (because it was declared in an assembly it has no references to), and so it cannot convert it into something it can use. This part may work in Python what with the duck-typing, I donât know.
If you wish to send data from one script component to another, you have the following options in C#:
Use an existing type, for example string. A lot of data could be converted from and to strings, so this allows you to exchange data through regular channels. However it may not be possible in some cases, or may be so involved/expensive that itâs not worth the effort.
Use a framework type which is accessible from both components, for example SortedDictionary<int, byte[]>. Both components have access to the type declaration so casting is no issue. To exchange an instance which does not implement IGH_Goo, you should wrap it up inside a GH_ObjectWrapper. That will prevent Grasshopper from trying to interpret your data and possibly changing it.
Create a dll using Visual Studio which declares the type and reference this dll from both script components. But at this point why not do everything in VS?
Write the data to a file on the disk and only share the file location. The other component then reads the data from the disk. This is a bit of a hack though and leads to potential conflicts or collisions.
You can pass anything you like (custom class instances, functions, nested lists, dictionaries etc) between GHPython components, by setting the input parameter type hint to No Type Hint. This is actually one of the things I really like/prefer about GHPython (as opposed to the other scripting components, if I understand how they work accurately). This can also aid in severely speeding things up by not casting/exposing large chunks of data to the GH canvas.
So in fact not passing the results as such (the class attributes and methods results) but rather passing the class itself to the output is the way to dealing with custom types.
You should follow what @piac suggested and override ToString method. Also you should initiate the class and output an instance of the class and not the class itself.
Not sure what your goals are but it looks like youâre trying to cast a method. Could you hold an instance of the cylinder youâre creating and return it?
This is not working for any custom type. This will only work for types that implement the interface.
You can see an example of a custom-bakeable entity here:
Please kindly read IronPython in Action, as gently mentioned last week. We unfortunately do not have the resources to distill a whole book, one question at a time.
A .Net interface (such as IGH_GeometricGoo) contains all methods and properties that can be overriden. For methods of a .Net class, methods and properties marked with virtual or override or abstract can be overriden. Python can mask all function names.
Thanks for the help, but what does this had to do with what Iâm asking? Iâm asking RhinoCommon / GH specific types. I doubt I can find GOO inside âIronPython in actionâ
I assume some objects can return GeometricGoo some donât.
When I was âswimmingâ through the Grasshopper api i found RefObject, with no explanation whatsoever where can I get it. I assume itâs coming from RhinoCommon or RhinoPythonScript but⌠since thereâs no example how can I figure that out. Iâm not a programmer and never will become one. I use âIronPython in Actionâ as a reference this is how I got this far. (I got the goo). Iâll try what @Alain said when I got back home.
EDIT:
If there was a template for creating âcustom GH Brep typeâ, âcustom GH Geometry typeâ, âcustom GH tree typeâ, âcustom GH vector typeâ, etc. and more python examples in the API I wouldnât have to ask so many stupid (for you) questions.
This page from the _GrasshopperSDKDocumentation command probably answers the question you ask from the Grasshopper-SDK perspective. Also available online.
But there is no need to (and we actually hope that you do not) create a âcustom Brep typeâ unless you actually create a new geometry type.
So, for custom âBrepâ type, there is no guide. Custom DataTree is not possible in any language because Grasshopper expects its own trees. There is an example with a new data type âtristateâ, in the Grasshopper SDK documentation, that I linked above. Also, there is an example in Python with a bakable data type in the link I sent before.
Alainâs answer is generic (because your question was generic), but it wonât mean something for the Grasshopper UI. It may mean something for your (future) components.
In reality, your questions regarding custom types can be entirely Grasshopper-SDK-free. You can just add the types you need, and as long as your components understand each other, they will work perfectly fine with one another.
If you want to program such an operation, you need to learn first. And inevitably youâll be a developer.
Arguably you are now one already. Just a novice one.
I was printing a lot of things trying to understand what does RefObject require in order to do the Convert or the CastTo
EDIT:
I do not understand why this:
returns Bool instead of Brep?
Logic implies a ConvertTo should result in the product of the conversion and not True or False. If Convert coins ToBankNotes and the result = 0 or 1. The World will bankrupt.
If the result was âFalseâ, then donât try to use the rc Brep, because itâs value can be rubbish. Only if the function returns True you can use rc and expect it to be meaningful.
Iâve never used the GH_Convert class before, but notice the ârefâ keyword in the function signature, that means to pass in a Brep object by reference, which the method will then modify in-place. Something like this in C#:
Brep my_brep = null;
bool result = GH_Convert.ToBrep(data, ref my_brep, GH_Conversion.Primary);
if (result){
do_stuff_with( my_brep );
IronPython doesnât support this syntax directly and has some other mechanism of doing so, youâll have to search around for the specifics.
Yes, instead of returning a single item, in these cases IronPython returns a tuple with (bool, my_brep).
If you need to override a method that takes a by-reference parameter, the input variable will be like the result of clr.Reference(), which is an instance of the type System.StrongBox.
