Custom slider value passing
I am trying to write a custom control using “Drawable”. Now it is the last step. The variable “_Initializing_value” in the class cannot be updated in the main window in real time, even though I used “ParentWindow.Invalidate(True)”.
“m_label.Text” will never refresh with “_Initializing_value”
I tested it by printing “x_point_OnMouseUp” in the “OnMouseUp” event, but I didn’t see any change to “m_label.Text”
#! python 3
import Eto.Forms as ef
import Eto.Drawing as ed
class Slider_tom(ef.Drawable):
    def __init__(self , Initializing_value , Minimum_value , Maximum_value):
        super().__init__()
        self.Width = Maximum_value
        self.Height = 25
        self._Initializing_value = Initializing_value
        self._Initializing_value_point = ed.PointF(Initializing_value , self.Height*0.5)
        self._Minimum_value = Minimum_value
        self._Maximum_value = Maximum_value
        self._Starting_point = ed.PointF(self._Minimum_value ,self.Height*0.5)
        self._end_point = ed.PointF(self._Maximum_value , self.Height*0.5)
        self._lin_a = ed.Pen(ed.Colors.CornflowerBlue, 1)
        self._Starting_point_rct = ed.SizeF(10,10)
        self._Colors_Starting_point_rct = ed.Colors.PaleVioletRed
        self._Initializing_value_point_mouse = ed.PointF(Initializing_value , self.Height*0.5)
        self._Initializing_value_point_mouse_OnMouseUp = ed.PointF(Initializing_value , self.Height*0.5)
        self._valve_value = 1
    def OnPaint(self,e):
        e.Graphics.DrawLine(self._lin_a, self._Starting_point ,self._end_point)
        if self._valve_value == 1:
            Starting_point_rct = ed.RectangleF.FromCenter(self._Initializing_value_point, self._Starting_point_rct)
        elif self._valve_value == 0:
            Starting_point_rct = ed.RectangleF.FromCenter(self._Initializing_value_point_mouse, self._Starting_point_rct)
        elif self._valve_value == 2:
            Starting_point_rct = ed.RectangleF.FromCenter(self._Initializing_value_point_mouse_OnMouseUp, self._Starting_point_rct)
        else:
            pass
        e.Graphics.FillEllipse(self._Colors_Starting_point_rct, Starting_point_rct)
        pass
    def OnMouseEnter(self, e):
        pass
    def OnMouseLeave(self, e):
        pass
    def OnMouseMove(self, e):
        x_point = e.Location.X
        self._Initializing_value_point_mouse = ed.PointF(x_point , self.Height * 0.5)
        self.Invalidate(True)
        pass
    def OnMouseDown(self, e):
        self._valve_value = 0
        pass
    def OnMouseUp(self, e):
        self.x_point_OnMouseUp = e.Location.X
        self._Initializing_value = self.x_point_OnMouseUp #This
        self._Initializing_value_point_mouse_OnMouseUp = ed.PointF(self.x_point_OnMouseUp , self.Height * 0.5)
        self._valve_value = 2
        print(self.x_point_OnMouseUp)
        self.Invalidate(False)
        self.ParentWindow.Invalidate(True)
        pass
if __name__ == "__main__":
    form = ef.Form()
    form.Width = 300
    form.Height = 300
    Slider = Slider_tom(Initializing_value = 10 , Minimum_value=0 , Maximum_value=100)
    m_label = ef.Label()
    m_label.Text = str(Slider._Initializing_value)
    Layout_0 = ef.PixelLayout()
    Layout_0.Add(Slider,0,0)
    Layout_0.Add(m_label,120,0)
    form.Content = Layout_0
    form.Show()
I am now in the school dormitory, can not sleep at all, who will help me
The issue is that updating the label (or any UI element) needs to happen inside an event handler. For example, to update the label when the mouse is released, you can do this:
    m_label.Text = str(e.Location.X)
However, OnMouseUp might not be the ideal place for this, especially if you want real-time updates while dragging. A more intuitive approach is to track mouse dragging with these event handlers:
    self._dragging = True
    self._dragging = False
    if self._dragging:
        self._value = self._clamp(e.Location.X)
        self._label.Text = str(int(self._value))
Here’s the full simplified version of the working slider:
#! python 3
class SimpleSlider(ef.Drawable):
    def __init__(self, value, min_val, max_val, label):
        super().__init__()
        self._min = min_val
        self._max = max_val
        self._value = self._clamp(value)
        self._label = label
        self.Width = max_val
        self.Height = 25
        self._handle_size = 10
    def _clamp(self, x):
        return max(self._min, min(self._max, x))
    def _handle_position(self):
        return ed.PointF(self._value, self.Height * 0.5)
    def OnPaint(self, e):
        line_start = ed.PointF(self._min, self.Height * 0.5)
        line_end = ed.PointF(self._max, self.Height * 0.5)
        e.Graphics.DrawLine(ed.Pen(ed.Colors.CornflowerBlue, 1), line_start, line_end)
        handle_rect = ed.RectangleF.FromCenter(self._handle_position(), ed.SizeF(self._handle_size, self._handle_size))
        e.Graphics.FillEllipse(ed.Colors.PaleVioletRed, handle_rect)
        if self._dragging:
    form = ef.Form()
    form.Width = 300
    form.Height = 100
    label = ef.Label()
    slider = SimpleSlider(value=10, min_val=0, max_val=100, label=label)
    layout = ef.PixelLayout()
    layout.Add(slider, 10, 10)
    layout.Add(label, 120, 10)
    form.Content = layout
    form.Show()
Thank you very much, this is perfect, I learned new knowledge today, I will remember to update changes in the event
